Aller au contenu principal
Lenovo IdeaPad 100s-14IBR Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 100s-14IBR Battery Replacement, Battery: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Battery Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: étape 2, image 2 de 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Battery Replacement: étape 3, image 1 de 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: étape 3, image 2 de 2
    • Remove six 4mm Phillips #00 screws.
    • Pull the battery connector parallel to the motherboard to disconnect the battery from the motherboard.
  4. Lenovo IdeaPad 100s-14IBR Battery Replacement: étape 4, image 1 de 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: étape 4, image 2 de 2
    • Use a nylon spudger to pry the battery up and out of the device.
Mohammed Younis
Membre depuis le 03/18/19
421 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 30
Total : 4,139
