Introduction
Use this guide to replace the motherboard in a Lenovo IdeaPad 310-15IKB.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Flip the laptop over with the hinge facing away from you.
Use a Phillips screwdriver to remove the twelve 6.5 mm screws that secure the lower case and the right panel.
Insert the flat end of a spudger into the notch on the upper left corner of the right panel.
Pry the panel up to release the retaining clips that secure the panel.
Remove the panel.
Use a Phillips screwdriver to remove the three 6.6 mm screws that secure the motherboard to the lower case.
Use the flat end of a spudger or a fingernail to flip up the ZIF locking flaps on the keyboard and trackpad connectors.
Use blunt tweezers to pull the keyboard ribbon cable directly out of its socket.
Use blunt tweezers to pull the trackpad ribbon cable directly out of its port.
Use the pointed tip of a spudger to gently pry up and disconnect the two antenna cables from the wireless card.
Insert the tip of an opening pick into the seam between the top left corner of the lower case and keyboard assembly.
Slide the opening pick down to the bottom left corner to release the clips.
Insert the tip of an opening pick into the seam between the lower left side of the palm rest and the lower case.
Slide the opening pick to the right to release the clips that secure the front edge.
Insert the tip of an opening pick into the bottom right seam between the chassis and keyboard assembly.
Slide the pick toward the top right corner to release the remaining retaining clips.
Use two opening tools or your fingernails to gently "walk" the battery connection directly out of its motherboard socket.
Use a Phillips screwdriver to remove the four 3.3 mm screws that secure the motherboard to the lower case.
Use the flat end of a spudger to flip up the ZIF locking flap that secures the display cable.
Outil utilisé dans cette étape :Tweezers$4.99
Use blunt tweezers to pull the display cable directly out of its motherboard socket.
Use tweezers to lift the display cable vertically to unseat it from the motherboard.
Use the pointed end of a spudger or your fingernails to gently "walk" the speaker cable directly out of its motherboard socket.
Use the flat end of a spudger to flip up each of the two ZIF locking flaps that secure the HDD and I/O board ribbon cables to the motherboard.
Use blunt tweezers to disconnect the the HDD and I/O board ribbon cables from their motherboard ports.
Use the flat end of a spudger to flip up the ZIF locking flap that secures the optical drive ribbon cable.
Use blunt tweezers to gently pull the optical drive ribbon cable directly out of its motherboard port.
Slightly lift the right side of the motherboard.
Slide the motherboard a few millimeters to the right to unseat the ports from the lower case.
Grasp both sides of the motherboard and lift it up and out.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
