Aller au contenu principal
Lenovo IdeaPad Flex 5-1570 RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 2, image 1 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 2, image 2 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 2, image 3 de 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 3, image 1 de 2 Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 3, image 2 de 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: étape 4, image 1 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: étape 4, image 2 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: étape 4, image 3 de 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: étape 5, image 1 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: étape 5, image 2 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: étape 5, image 3 de 3
    • Push the two tabs on both sides of the RAM stick apart to release the memory module.
    • The RAM will rise up to rest at an angle to the motherboard.
  6. Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 6, image 1 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 6, image 2 de 3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: étape 6, image 3 de 3
    • Pull the RAM stick out of its port with respect to the angle at which it rests.
    • Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
2 autres ont terminé cette réparation.
Austin Blakely
Membre depuis le 03/11/19
19 631 Réputation
53 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 298 tutoriels rédigés
4 commentaires
I've had a Lenovo Flex 5 for a number of years and it has been extremally reliable. I wasn't aware that upgrading anything on this unit was even possible. Thank you for this info, I'll be checking into this more.
John - Réponse
Please suggest what DDR4 RAM I should buy to replace it. I have a 16 GB, I want to go 32 or 64.
Maulik Darji - Réponse
"Patriot Viper Steel DDR4 32GB 2400MHz CL15 SODIMM Memory Module PVS432G240C5S" works on mine
Finality Video -
Thank you for posting this and especially to the commentor that posted the memory upgrade info. This has been a great laptop and I look for to extending the life of it with this upgrade.
Vee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 34
30 derniers jours : 156
Total : 9,082
