Aller au contenu principal
Lenovo IdeaPad Flex 5-1570 Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 2, image 1 de 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 2, image 2 de 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 2, image 3 de 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 3, image 1 de 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 3, image 2 de 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 5, image 2 de 2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  6. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: étape 6, image 1 de 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: étape 6, image 2 de 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: étape 6, image 3 de 3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 7, image 2 de 2
    • Using your hands, gently pull the left speaker up and out of the device.
  8. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 8, image 1 de 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: étape 8, image 2 de 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
Nate Blake
Membre depuis le 01/23/20
507 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S2-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 468
