Aller au contenu principal
Lenovo IdeaPad Flex 5-1570 USB Port Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 2, image 1 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 2, image 2 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 2, image 3 de 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 3, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 3, image 2 de 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Fan: étape 4, image 1 de 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 5, image 1 de 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 6, image 2 de 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  7. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: étape 7, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: étape 7, image 2 de 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  8. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 8, image 1 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 8, image 2 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 8, image 3 de 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  9. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: étape 9, image 1 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: étape 9, image 2 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: étape 9, image 3 de 3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  10. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 10, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 10, image 2 de 2
    • Using your hands, gently pull the left speaker up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 11, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 11, image 2 de 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  12. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Motherboard: étape 12, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  13. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 13, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 13, image 2 de 2
    • Disconnect the auxiliary port cable from the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 14, image 1 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 14, image 2 de 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 14, image 3 de 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  15. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 15, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 15, image 2 de 2
    • Disconnect the display cable from the motherboard.
  16. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 16, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 16, image 2 de 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 17, image 1 de 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: étape 17, image 2 de 2
    • Carefully lift and remove the motherboard from the device.
  18. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, USB Port: étape 18, image 1 de 1
    • Once you've removed the motherboard, desolder the four contact points on the USB connector.
    • For proper technique on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the USB port from the device.
    • Resolder the new USB connector in the same place.
Nate Blake
Membre depuis le 01/23/20
507 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S2-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 membres
13 tutoriels rédigés
2 commentaires
what is the replacement part number?
Edwin Maynard - Réponse
Was anyone able to find a part number for the specific USB ports?
Greg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 36
Total : 2,820
