Aller au contenu principal
Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Base Cover: étape 1, image 1 de 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: étape 3, image 1 de 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: étape 3, image 2 de 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: étape 3, image 3 de 3
    • Remove the six 3.5 mm screws that secure the fans in place using a Phillips #00 screwdriver.
    • Loosen the seven captive screws using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to unwind the black and gray wires from the clips that are holding them onto the left side fan.
  5. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 5, image 2 de 2
    • Lift the black piece of cloth tape that secures the right side fan wires to the circuit board.
  6. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 6, image 1 de 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 6, image 2 de 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 6, image 3 de 3
    • Use tweezers to unplug the wiring connectors that are connected to each fan.
  7. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: étape 7, image 2 de 2
    • Gently remove the fans from the laptop.
    • There is thermal paste attaching the ducting of the fans that will require some careful prying.
    • When replacing the fan, reapply a pea sized amount of thermal paste to the fan ducts.
Nico Magtoto
Membre depuis le 01/09/22
489 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 472
