Aller au contenu principal
Lenovo Ideapad 320-15IAP Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: étape 1, image 1 de 2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: étape 2, image 1 de 1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: étape 3, image 1 de 1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: étape 4, image 1 de 2 Lenovo Ideapad 320-15IAP Battery Replacement: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: étape 5, image 1 de 2 Lenovo Ideapad 320-15IAP Battery Replacement: étape 5, image 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: étape 6, image 1 de 1
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 54
Total : 1,114
