Aller au contenu principal
Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the lower case: étape 1, image 1 de 2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the lower case: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Insert an opening pick: étape 2, image 1 de 2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Insert an opening pick: étape 2, image 2 de 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: étape 3, image 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: étape 3, image 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: étape 3, image 3 de 3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: étape 4, image 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: étape 4, image 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: étape 4, image 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: étape 5, image 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: étape 5, image 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: étape 5, image 3 de 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  6. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the right SSD: étape 6, image 1 de 2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the right SSD: étape 6, image 2 de 2
    • Use a Phillips screwdriver to remove the 2.4 mm screw securing the right SSD.
  7. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: étape 7, image 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: étape 7, image 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: étape 7, image 3 de 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
Spencer Day
Membre depuis le 09/14/22
59 678 Réputation
430 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 895 tutoriels rédigés
4 commentaires
Hello u said the wrong m.2 size its not M.2 2230 SSD its a m.2 2242
Matthew Dhanraj - Réponse
Thanks for the article... So the right ssd is M.2 2242 NVME
mfarhanfp - Réponse
what type of SSD is that?
Gloabl - Réponse
Hi! As stated in the introduction, this is an M.2 2242 SSD.
Spencer Day -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 71
30 derniers jours : 277
Total : 6,044
