Aller au contenu principal
Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement
Ce dont vous avez besoin
  1. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: étape 1, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.7 mm PH00 screws
    • Four 4.2 mm PH00 screws
  2. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: étape 2, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: étape 2, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: étape 2, image 3 de 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 3, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 3, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 3, image 3 de 3
    • Angle the pick to about 45˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: étape 4, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: étape 4, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: étape 4, image 3 de 3
    • Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
  5. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: étape 5, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: étape 5, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: étape 5, image 3 de 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: étape 6, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: étape 6, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: étape 6, image 3 de 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 7, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 7, image 2 de 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: étape 8, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: étape 8, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: étape 8, image 3 de 3
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 9, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 9, image 2 de 2
  10. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: étape 10, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: étape 10, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: étape 10, image 3 de 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: étape 11, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: étape 11, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: étape 11, image 3 de 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 12, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 12, image 2 de 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: étape 13, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: étape 13, image 2 de 2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the left SSD shield to the motherboard.
    • During reassembly, make sure the hole on the top of the shield aligns with the post on the chassis.
  14. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: étape 14, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: étape 14, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: étape 14, image 3 de 3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 15, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: étape 15, image 2 de 2
    • Use a Phillips screwdriver to remove the 2.6 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: étape 16, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: étape 16, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: étape 16, image 3 de 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
3 autres ont terminé cette réparation.
Chayton Ritter
Membre depuis le 08/21/20
22 506 Réputation
105 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
9 membres
11 414 tutoriels rédigés
Un commentaire
@chaytonr What's the maximum supported SSD capacity for Lenovo Legion 5 Pro 16ACH6H? I already have a 1TB SSD on the right slot but can i intall a 2TB SSD on the left slot for a total of 3TB storage?
Ayush Patel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 26
30 derniers jours : 137
Total : 7,320
