Aller au contenu principal
Lenovo Legion Y520-15IKBN Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Legion Y520-15IKBN Battery  Replacement, Base Panel: étape 1, image 1 de 1
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Battery  Replacement: étape 2, image 1 de 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Battery  Replacement, Battery: étape 3, image 1 de 1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  4. Lenovo Legion Y520-15IKBN Battery  Replacement: étape 4, image 1 de 2 Lenovo Legion Y520-15IKBN Battery  Replacement: étape 4, image 2 de 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  5. Lenovo Legion Y520-15IKBN Battery  Replacement: étape 5, image 1 de 1
    • Lift the battery up and out of the chassis.
11 autres ont terminé cette réparation.
Naomi Williams
Membre depuis le 10/04/18
771 Réputation
2 tutoriels rédigés
Équipe
3 commentaires
Thank you, very helpful.
ska Smith - Réponse
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Ricardo Peixoto - Réponse
Hello
I dont know if you are gonna read this, but you could try to glue the connector with Superglue to the board, but watch out to not tear it off or put superglue into the connector.
electro -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 53
30 derniers jours : 214
Total : 22,084
