Aller au contenu principal
Lenovo ThinkPad Edge E420s Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 3, image 1 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 3, image 2 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 3, image 3 de 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 4, image 1 de 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 5, image 1 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 5, image 2 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: étape 5, image 3 de 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
4 autres ont terminé cette réparation.
Keyadri Summerlin
Membre depuis le 10/02/18
1 003 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 44
Total : 2,862
