Aller au contenu principal
Lenovo ThinkPad T431S Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: étape 1, image 1 de 2 Lenovo ThinkPad T431S Battery Replacement, Battery: étape 1, image 2 de 2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T431S Battery Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T431S Battery Replacement: étape 2, image 3 de 3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T431S Battery Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T431S Battery Replacement: étape 3, image 3 de 3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 21
Total : 1,226
