Aller au contenu principal
Lenovo ThinkPad T460s Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T460s Battery Replacement, Battery: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Battery Replacement: étape 2, image 1 de 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Battery Replacement: étape 3, image 1 de 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Battery Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T460s Battery Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T460s Battery Replacement: étape 4, image 3 de 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
15 autres ont terminé cette réparation.
14 commentaires de tutoriel
I have a question, please. Are the two batteries identical?
Felipe L.R. - Réponse
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Jonas Andersen - Réponse
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 21
7 derniers jours : 126
30 derniers jours : 546
Total : 58,231
