Aller au contenu principal
Lenovo ThinkPad T470s Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T470s Motherboard Replacement, Bottom Panel: étape 1, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470s Motherboard Replacement, Batteries: étape 2, image 1 de 3 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: étape 2, image 2 de 3 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: étape 2, image 3 de 3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470s Motherboard Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T470s Motherboard Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T470s Motherboard Replacement: étape 3, image 3 de 3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
  4. Lenovo ThinkPad T470s Motherboard Replacement, Fan and Heat Sink: étape 4, image 1 de 1
    • Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
  5. Lenovo ThinkPad T470s Motherboard Replacement: étape 5, image 1 de 1
    • Unplug the fan from the motherboard.
  6. Lenovo ThinkPad T470s Motherboard Replacement: étape 6, image 1 de 1
    • Remove the heatsink and fan from the laptop.
  7. Lenovo ThinkPad T470s Motherboard Replacement: étape 7, image 1 de 1
    • Wipe off the old thermal paste with either 99% isopropyl alcohol or kimwipes.
  8. Lenovo ThinkPad T470s Motherboard Replacement: étape 8, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement: étape 8, image 2 de 2
  9. Lenovo ThinkPad T470s Motherboard Replacement, Wi-Fi Card: étape 9, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  10. Lenovo ThinkPad T470s Motherboard Replacement: étape 10, image 1 de 1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
  11. Lenovo ThinkPad T470s Motherboard Replacement, USB Board: étape 11, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement, USB Board: étape 11, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo ThinkPad T470s Motherboard Replacement: étape 12, image 1 de 1
    • Use your fingernail to flip up the gate, then pull the connector directly out of the port.
  13. Lenovo ThinkPad T470s Motherboard Replacement: étape 13, image 1 de 1
    • Lift the USB board up and out of the chassis.
  14. Lenovo ThinkPad T470s Motherboard Replacement, SSD: étape 14, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement, SSD: étape 14, image 2 de 2
    • Locate the SSD slot between the large battery and fan.
    • Remove the screw securing the SSD using a Phillips #000 screwdriver.
  15. Lenovo ThinkPad T470s Motherboard Replacement: étape 15, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement: étape 15, image 2 de 2
    • Slide the SSD out of the motherboard.
  16. Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: étape 16, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: étape 16, image 2 de 2
    • Flip up the locking gate, then pull the cable directly out of its port.
    • Use a Phillips #0 screwdriver to remove the single 3.3 mm screw on the top right corner of the motherboard.
  17. Lenovo ThinkPad T470s Motherboard Replacement: étape 17, image 1 de 1
    • Remove the single 3.3 mm screw with a Phillips #0 screwdriver.
  18. Lenovo ThinkPad T470s Motherboard Replacement: étape 18, image 1 de 1
  19. Lenovo ThinkPad T470s Motherboard Replacement: étape 19, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw.
  20. Lenovo ThinkPad T470s Motherboard Replacement: étape 20, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement: étape 20, image 2 de 2
    • Disconnect the speaker connection covering the screw.
    • Use a Phillips #0 screwdriver to remove the single 5 mm screw securing the motherboard.
  21. Lenovo ThinkPad T470s Motherboard Replacement: étape 21, image 1 de 1
    • Remove the 3.3 mm screw using a Phillips #0 screwdriver.
  22. Lenovo ThinkPad T470s Motherboard Replacement: étape 22, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the 3.3 mm screw.
  23. Lenovo ThinkPad T470s Motherboard Replacement: étape 23, image 1 de 1
  24. Lenovo ThinkPad T470s Motherboard Replacement: étape 24, image 1 de 2 Lenovo ThinkPad T470s Motherboard Replacement: étape 24, image 2 de 2
    • Gently grip the motherboard and slide it to the right to remove the USB ports from the chassis.
    • You will hear an audible clicking sound.
    • Lift the motherboard up and out of the chassis.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 22
30 derniers jours : 119
Total : 2,604
