Aller au contenu principal
Lenovo ThinkPad T490 RAM Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T490 RAM Replacement, Unscrew the base plate: étape 1, image 1 de 1
    • Remove the screws from the base plate for access to the motherboard using a Philips #00 screwdriver.
  2. Lenovo ThinkPad T490 RAM Replacement, Pry the base plate off: étape 2, image 1 de 2 Lenovo ThinkPad T490 RAM Replacement, Pry the base plate off: étape 2, image 2 de 2
    • Once the screws are off, start to pry the base plate off.
    • Fully remove the base plate so you can access the RAM.
  3. Lenovo ThinkPad T490 RAM Replacement, Locate components: étape 3, image 1 de 1
    • Locate the RAM module (blue box on the left)…
    • …and the laptop's battery (pink box on the right).
  4. Lenovo ThinkPad T490 RAM Replacement, Disconnect the battery: étape 4, image 1 de 2 Lenovo ThinkPad T490 RAM Replacement, Disconnect the battery: étape 4, image 2 de 2
    • First, for the reinstallation process, disconnect and remove the battery.
    • Be cautious when handling any batteries. A punctured or damaged battery is a fire risk and should be disposed of immediately.
    • To remove the RAM battery, tug the black cables and disconnect the metal head from the socket.
  5. Lenovo ThinkPad T490 RAM Replacement, Remove the RAM stick: étape 5, image 1 de 2 Lenovo ThinkPad T490 RAM Replacement, Remove the RAM stick: étape 5, image 2 de 2
    • For the RAM stick, first remove the black flap that is covering it.
    • Once the black flap is removed, slide the RAM stick out for further inspection. Slide it back in and place the black flap over it to restart the process.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
ferni fuentes
Membre depuis le 02/19/24
571 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 44
30 derniers jours : 175
Total : 1,280
