Aller au contenu principal
Lenovo ThinkPad T560 Fan Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: étape 1, image 1 de 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Fan Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad T560 Fan Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Fan Replacement: étape 4, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: étape 5, image 1 de 3 Lenovo ThinkPad T560 Fan Replacement, Fan: étape 5, image 2 de 3 Lenovo ThinkPad T560 Fan Replacement, Fan: étape 5, image 3 de 3
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
  6. Lenovo ThinkPad T560 Fan Replacement: étape 6, image 1 de 1
    • Unplug the fan from the motherboard.
  7. Lenovo ThinkPad T560 Fan Replacement: étape 7, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
  8. Lenovo ThinkPad T560 Fan Replacement: étape 8, image 1 de 1
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
Jackson Reynolds
Membre depuis le 02/27/22
517 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-3, Hunter Spring 2022 Membre de l'équipe Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 21
Total : 739
