Aller au contenu principal
Lenovo ThinkPad T580 Internal Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T580 Internal Battery Replacement, External Battery: étape 1, image 1 de 3 Lenovo ThinkPad T580 Internal Battery Replacement, External Battery: étape 1, image 2 de 3 Lenovo ThinkPad T580 Internal Battery Replacement, External Battery: étape 1, image 3 de 3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Internal Battery Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 2, image 3 de 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Internal Battery Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 3, image 3 de 3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Internal Battery Replacement, Bottom Case: étape 4, image 1 de 2 Lenovo ThinkPad T580 Internal Battery Replacement, Bottom Case: étape 4, image 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Internal Battery Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 5, image 3 de 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Internal Battery Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 6, image 3 de 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Internal Battery Replacement, Internal Battery: étape 7, image 1 de 1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Internal Battery Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T580 Internal Battery Replacement: étape 8, image 3 de 3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
2 autres ont terminé cette réparation.
Ben Elkayam
Membre depuis le 01/23/20
954 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team S18-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G6, White Winter 2020
CPSU-WHITE-W20S18G6
4 membres
24 tutoriels rédigés
Un commentaire
I need to buy the internal battery
Bwambale Landus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 47
30 derniers jours : 236
Total : 9,308
