Aller au contenu principal
Lenovo ThinkPad X201 Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X201 Hard Drive Replacement, Turn the system off and remove the battery: étape 1, image 1 de 2 Lenovo ThinkPad X201 Hard Drive Replacement, Turn the system off and remove the battery: étape 1, image 2 de 2
    • You do not want the computer running while you're doing this. Before you start, make sure to turn the machine off if it's currently on.
    • Disconnect the power cord, flip the laptop over and disconnect the battery by unlocking the lock tab and pushing the battery towards the back side of the device.
    • Once both the battery and power cord have been disconnected, hold the power button for a few seconds to flush any remaining power from the capacitors.
  2. Lenovo ThinkPad X201 Hard Drive Replacement, Locate the storage bay: étape 2, image 1 de 1
    • Unscrew the single PH0 screw from the storage compartment door
  3. Lenovo ThinkPad X201 Hard Drive Replacement, Unscrew the storage bay door: étape 3, image 1 de 1
    • Get a Phillips #0 screwdriver.
    • Stick the screwdriver in the screw.
    • Twist the screwdriver counter-clockwise in order to loosen it up.
  4. Lenovo ThinkPad X201 Hard Drive Replacement, Cool, now let's pull the drive mount out: étape 4, image 1 de 2 Lenovo ThinkPad X201 Hard Drive Replacement, Cool, now let's pull the drive mount out: étape 4, image 2 de 2
    • Pull out the hard drive compartment door
    • Cool. Now use your fingers to unfold the black plastic pull tab and pull the drive out.
  5. Lenovo ThinkPad X201 Hard Drive Replacement, Unscrewing the drive from the bracket: étape 5, image 1 de 2 Lenovo ThinkPad X201 Hard Drive Replacement, Unscrewing the drive from the bracket: étape 5, image 2 de 2
    • Use your #0 Phillips screwdriver and remove the 4 screws from the hard drive bracket, two on each side.
    • Now, pull the hard drive out of the bracket with your fingers. Make sure not to stress the SATA connectors on the bottom side of the drive.
  6. Lenovo ThinkPad X201 Hard Drive Replacement, Put a new drive in the bracket: étape 6, image 1 de 3 Lenovo ThinkPad X201 Hard Drive Replacement, Put a new drive in the bracket: étape 6, image 2 de 3 Lenovo ThinkPad X201 Hard Drive Replacement, Put a new drive in the bracket: étape 6, image 3 de 3
    • Get your new drive, and just put it in. Make sure the SATA ports face the end of the bracket that does not have the pull tab, and that the L-shaped connectors have their short side pointing down towards the metal plate.
    • Screw the four screws back in, and put the protective rubber back on the sides of the bracket.
    • Flip the drive upside down, with the gold contacts facing towards you and gently put it back in the drive slot.
    • Make sure that the pull tab is facing away from the laptop.
  7. Lenovo ThinkPad X201 Hard Drive Replacement, Finalizing: étape 7, image 1 de 3 Lenovo ThinkPad X201 Hard Drive Replacement, Finalizing: étape 7, image 2 de 3 Lenovo ThinkPad X201 Hard Drive Replacement, Finalizing: étape 7, image 3 de 3
    • Neatly tuck the pull tab under the bracket, like in the picture.
    • Get the plastic hard drive bay door, and put it back into place.
    • Get the screw you used for the door, and screw it back in.
  8. Lenovo ThinkPad X201 Hard Drive Replacement, Check that the new drive is installed and working properly: étape 8, image 1 de 3 Lenovo ThinkPad X201 Hard Drive Replacement, Check that the new drive is installed and working properly: étape 8, image 2 de 3 Lenovo ThinkPad X201 Hard Drive Replacement, Check that the new drive is installed and working properly: étape 8, image 3 de 3
    • Turn the ThinkPad on.
    • When you see the ThinkPad logo, press the blue ThinkVantage button and go into the BIOS menu by pressing F1.
    • Go into "HDD diagnostic program", and press "Main hard disk drive".
    • Wait for it to finish benchmarking your drive. This could take a while, but it does tell you how to abort it.
I hope you had fun doing this.
You will now need to install your operating system and copy your files back. For Windows, follow these instructions. For linux-based or other OSes, follow the guide supplied by your distribution. (For this device, the boot selection menu can be entered by pressing F12 when the ThinkPad logo shows on startup)
I'm Someone
Membre depuis le 06/22/22
157 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 53
Total : 1,745
