Aller au contenu principal
Lenovo ThinkPad X280 Touch Pad Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X280 Touch Pad Replacement, Back Panel: étape 1, image 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Touch Pad Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X280 Touch Pad Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Touch Pad Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X280 Touch Pad Replacement: étape 3, image 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Touch Pad Replacement, Battery: étape 4, image 1 de 3 Lenovo ThinkPad X280 Touch Pad Replacement, Battery: étape 4, image 2 de 3 Lenovo ThinkPad X280 Touch Pad Replacement, Battery: étape 4, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Touch Pad Replacement, Touch Pad: étape 5, image 1 de 2 Lenovo ThinkPad X280 Touch Pad Replacement, Touch Pad: étape 5, image 2 de 2
    • Carefully peel off the black tape covering the touchpad connector with your fingers.
    • Use tweezers if you're having trouble gripping the tape.
  6. Lenovo ThinkPad X280 Touch Pad Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X280 Touch Pad Replacement: étape 6, image 2 de 2
    • Using a spudger, lift the small latch on the cable connector, then slide the cable out carefully to disconnect it.
    • In the second photo, the connector broke off. Gently pull the ribbon cable out of its socket.
  7. Lenovo ThinkPad X280 Touch Pad Replacement: étape 7, image 1 de 1
    • Remove the four 3.4 mm Phillips #0 screws that secure the touchpad.
    • With a tweezer or your hands, carefully remove any adhesive/tape securing the touchpad in place.
    • You may need to gently pry the touchpad free with a spudger.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ruth O
Membre depuis le 09/23/24
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 35
Total : 152
