Introduction
If the Lenovo ThinkPad Yoga 11e Gen 6 is having performance issues, (i.e., CPU response time, application launch time, system responsiveness, etc) it may need a new motherboard. Follow this guide to safely replace the motherboard in the Lenovo ThinkPad Yoga 11e Gen 6.
Ce dont vous avez besoin
Disconnect the laptop from power and make sure it is completely powered off.
Turn the laptop facing down.
Loosen the eight captive screws using a JIS #0 screwdriver.
Use a spudger to release the tabs securing the back case and carefully remove the panel.
Push on alternating sides of the JST connector and pull straight away from the socket to disconnect the CMOS battery.
Loosen the four captive screws from the metal panel with a copper strip on it using a Phillips #0 screwdriver.
Carefully lift the metal panel. The screws are attached to the panel and will not come out.
