Aller au contenu principal
Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Battery: étape 1, image 1 de 2 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Back Cover: étape 2, image 1 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Back Cover: étape 2, image 2 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Back Cover: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Keyboard: étape 3, image 1 de 2 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Keyboard: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
  4. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 4, image 1 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 4, image 2 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 4, image 3 de 3
    • Flip the laptop back over, showing the keyboard.
    • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
    • You should see two ribbon wires located beneath the keyboard once you are done.
  5. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 5, image 1 de 2 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Pull on the black tabs above both ribbon wires using tweezers upwards.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Remove both ribbon wires.
    • Remove the keyboard from the laptop.
  6. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement, Touchpad and Midframe Assembly: étape 6, image 1 de 1
    • Using the Phillips #1 screwdriver, remove three 8 mm screws.
  7. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 7, image 1 de 1
    • Flip the laptop over to the front.
    • Using the same Phillips #1 screwdriver, remove three 4 mm screws.
  8. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 8, image 1 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 8, image 2 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 8, image 3 de 3
    • Pull up on the small black tabs using precision tweezers for the two ribbon wires.
    • Disconnect the two ribbon wires.
  9. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 9, image 1 de 2 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 9, image 2 de 2
    • Disconnect the black wire by pulling it out gently.
  10. Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 10, image 1 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 10, image 2 de 3 Lenovo ThinkPad x120e Touchpad and Midframe Assembly Replacement: étape 10, image 3 de 3
    • Pry open the palm rest using the spudger.
    • Remove the palm rest and set it aside.
    • You can start from anywhere, but the best place to start would be at the bottom of the keyboard.
Jacob Fronzaglia
Membre depuis le 10/25/21
787 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 21
Total : 268
