Aller au contenu principal
Lenovo V14-IIL Camera Replacement
Ce dont vous avez besoin
  1. Lenovo V14-IIL Camera Replacement, Back Panel: étape 1, image 1 de 2 Lenovo V14-IIL Camera Replacement, Back Panel: étape 1, image 2 de 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Camera Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Camera Replacement: étape 3, image 1 de 1
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Camera Replacement, Display Assembly: étape 4, image 1 de 2 Lenovo V14-IIL Camera Replacement, Display Assembly: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL Camera Replacement: étape 5, image 1 de 1
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL Camera Replacement: étape 6, image 1 de 2 Lenovo V14-IIL Camera Replacement: étape 6, image 2 de 2
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL Camera Replacement: étape 7, image 1 de 1
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
  8. Lenovo V14-IIL Camera Replacement, Screen Bezel: étape 8, image 1 de 2 Lenovo V14-IIL Camera Replacement, Screen Bezel: étape 8, image 2 de 2
    • Slide the cable hinge cover to the right.
    • Pull the part away from the screen.
  9. Lenovo V14-IIL Camera Replacement: étape 9, image 1 de 2 Lenovo V14-IIL Camera Replacement: étape 9, image 2 de 2
    • Use the iFixit opening tool to separate the bezel panel.
    • Slide the opening tool all the way around to loosen the bezels on all sides.
    • You may need to use the tool to gently loosen the adhesive tape.
    • Lift away the bezel panel.
  10. Lenovo V14-IIL Camera Replacement, Camera: étape 10, image 1 de 1
    • Gently pull out the stretch adhesive tape.
    • Make sure to pull from hinges to the top of the LCD panel.
    • You may need to use the metal spudger to help loosen the adhesive.
  11. Lenovo V14-IIL Camera Replacement: étape 11, image 1 de 1
    • Disconnect the wire from the back of the integrated camera and lift the camera away.
Sydney Askins
Membre depuis le 01/16/24
378 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 96
