Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo YOGA 730-15IKB Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Touchpad Replacement: étape 2, image 1 de 2 Lenovo YOGA 730-15IKB Touchpad Replacement: étape 2, image 2 de 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Touchpad Replacement: étape 3, image 1 de 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: étape 4, image 1 de 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: étape 4, image 2 de 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Touchpad Replacement: étape 5, image 1 de 2 Lenovo YOGA 730-15IKB Touchpad Replacement: étape 5, image 2 de 2
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Touchpad Replacement: étape 6, image 1 de 1
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: étape 7, image 1 de 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: étape 7, image 2 de 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: étape 7, image 3 de 3
    • The touchpad is connected by a ribbon cable to the front edge of the motherboard.
    • Pull up on the black tab on the touchpad cable connector.
    • The ribbon cable should easily pull out of the connector.
  8. Lenovo YOGA 730-15IKB Touchpad Replacement: étape 8, image 1 de 1
    • Remove six 2mm Phillips #000 screws.
    • Some of these screws may be hidden under other ribbon cables.
  9. Lenovo YOGA 730-15IKB Touchpad Replacement: étape 9, image 1 de 2 Lenovo YOGA 730-15IKB Touchpad Replacement: étape 9, image 2 de 2
    • Pull up on the top edge of the touchpad near the motherboard. Lift the touchpad up and out of the chassis.
2 autres ont terminé cette réparation.
Équipe
Cal Poly, Team S1-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 membres
27 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 23
30 derniers jours : 72
Total : 2,170
