Aller au contenu principal
Lenovo Yoga 900-13ISK Charging Port Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 900-13ISK Charging Port Replacement, Back Cover: étape 1, image 1 de 2 Lenovo Yoga 900-13ISK Charging Port Replacement, Back Cover: étape 1, image 2 de 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 2, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 2, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 2, image 3 de 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Charging Port Replacement, Battery: étape 3, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Battery: étape 3, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Battery: étape 3, image 3 de 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 4, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 4, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 4, image 3 de 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Charging Port Replacement, Solid State Drive: étape 5, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Solid State Drive: étape 5, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Solid State Drive: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
  6. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 6, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 6, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 6, image 3 de 3
    • Pull the SSD card out of the port to the right.
  7. Lenovo Yoga 900-13ISK Charging Port Replacement, Wi-Fi Card Prereq: étape 7, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Wi-Fi Card Prereq: étape 7, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Wi-Fi Card Prereq: étape 7, image 3 de 3
    • Pry up the gray and black coaxial cables from the Wi-Fi card using a spudger.
    • Move the cables to the side.
  8. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 8, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 8, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 8, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the 2.2 mm screw holding down the Wi-Fi card.
    • The Wi-Fi card may pop up to rest at an angle to the motherboard after the screw is removed.
  9. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 9, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 9, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 9, image 3 de 3
    • Pull the WiFi card out from the connector on the motherboard.
  10. Lenovo Yoga 900-13ISK Charging Port Replacement, Motherboard: étape 10, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Motherboard: étape 10, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Motherboard: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using the pointed end of a spudger, flip up the hinged locking tabs of the eight ZIF connectors on the motherboard.
    • Pull the eight cables out from their connectors using a pair of blunt nose tweezers.
  11. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 11, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 11, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 11, image 3 de 3
  12. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 12, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 12, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 12, image 3 de 3
    • Remove the five 3.6 mm screws from the motherboard using a Phillips #00 screwdriver.
  13. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 13, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 13, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 13, image 3 de 3
    • Pull back the interconnect cable on the left side of the motherboard to reveal one of the fan screws for the left fan.
    • Remove the two 3.6 mm screws from the left fan with a Phillips #00 screwdriver.
  14. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 14, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 14, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 14, image 3 de 3
    • Remove the two 3.6 mm screws from the right fan using a Phillips #00 screwdriver.
  15. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 15, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 15, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 15, image 3 de 3
    • Unwind the black and white coaxial cables from the hooks on the right fan casing.
  16. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 16, image 1 de 2 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 16, image 2 de 2
    • Lift the motherboard from the bottom edge and pull it up and out of the case.
    • If you need to remove the fan assembly to swap it over to your new motherboard, continue to follow along with the heatsink guide.
  17. Lenovo Yoga 900-13ISK Charging Port Replacement, Charging Port: étape 17, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Charging Port: étape 17, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement, Charging Port: étape 17, image 3 de 3
    • Remove the two 3.5 mm screws from the charging port with a Phillips #00 screwdriver.
  18. Lenovo Yoga 900-13ISK Charging Port Replacement: étape 18, image 1 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 18, image 2 de 3 Lenovo Yoga 900-13ISK Charging Port Replacement: étape 18, image 3 de 3
    • Peel up the charging port cable and remove the charging port.
Austin Blakely
Membre depuis le 03/11/19
19 652 Réputation
53 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 433 tutoriels rédigés
2 commentaires
Why did you have to remove the motherboard and all of its connections to replace the DC in cable? Couldn’t you have just removed the fan to get access to the DC in cable?
Chris - Réponse
Bruh, why don't you show how to reconnect the charging port? That's what I am stuck on. It looked easy and now I can't get it back in.
dianadiazsing - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 39
Total : 1,547
