Aller au contenu principal
Lenovo Yoga C930-13IKB Touch Pad Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga C930-13IKB Touch Pad Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 2, image 1 de 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 2, image 2 de 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 3, image 1 de 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 3, image 2 de 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: étape 4, image 1 de 3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: étape 4, image 2 de 3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: étape 4, image 3 de 3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 5, image 1 de 1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 6, image 1 de 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 6, image 2 de 2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: étape 7, image 1 de 2 Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: étape 7, image 2 de 2
    • Unscrew the four 2 mm screws with a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 8, image 1 de 3 Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 8, image 2 de 3 Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 8, image 3 de 3
    • Carefully pull out the small electrical wire from the back of the touch pad.
  9. Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 9, image 1 de 2 Lenovo Yoga C930-13IKB Touch Pad Replacement: étape 9, image 2 de 2
    • The touch pad must be slid out before being lifted out.
    • Lift up the touch pad.
    • Slide the touch pad out of the laptop.
Matteo
Membre depuis le 01/23/20
97 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S19-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 17
Total : 787
