Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo Yoga C930-13IKB Wi-Fi Card Replacement
Ce dont vous avez besoin
    1. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Back Cover: étape 1, image 1 de 1
      • Flip the device over so that the underside is facing up.
      • Remove the six 3.5 mm T5 Torx screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 2, image 1 de 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 2, image 2 de 2
      • Pry off the back cover using the plastic opening tool.
      • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
      • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
      • Do not use a metal tool when working with your device.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 3, image 1 de 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 3, image 2 de 2
      • Carefully lift the cover off with your hands.
      Demander à FixBot
    1. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 2 de 2
      • Find the Wi-Fi card located on the right just above the battery. It is a green chip with a white label that says "Intel 9260" somewhere on it.
      Demander à FixBot
    2. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 5, image 2 de 2
      • Use a Phillips #00 screwdriver to remove the single 2 mm screw that attaches the card to the motherboard.
      Demander à FixBot
    3. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 6, image 1 de 3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 6, image 2 de 3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 6, image 3 de 3
      Outil utilisé dans cette étape :
      iFixit Opening Tool
      $1.99
      • Gently pull or use the iFixit opening tool to detach the black and white wires from the card.
      • When reassembling, these wires are difficult to reattach, so be patient. Line the wires up with your fingers and press down on the connections with the opening tool.
      Demander à FixBot
    4. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 7, image 1 de 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: étape 7, image 2 de 2
      • Pinch the card on either side and pull to the right to unplug it from the motherboard.
      Demander à FixBot
5 autres ont terminé cette réparation.
Jessie Boucher
Membre depuis le 01/23/20
330 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S19-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 membres
51 tutoriels rédigés
2 commentaires de tutoriel
Brilliant! very clear instructions and it fixed my fault. I wonder if this is a relatively common fault. Windows unable to find WiFi adapter.
Thank you for your efforts
David Pugh - Réponse Partager
Does anyone know if i need a Lenovo specific 9260 or does any Intel 9260 card work?
the ones sold as a "lenovo" version is 3x the price where i am, so i would like to avoid that if possible.
Einstein Teigland - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 39
Total : 2,339
