Aller au contenu principal
Likebook Muses Motherboard Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 5 sont issues d'un tutoriel marqué comme en cours.
    Likebook Muses Motherboard Replacement, Power off: étape 1, image 1 de 1
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Motherboard Replacement, Rear Cover: étape 2, image 1 de 1
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Motherboard Replacement: étape 3, image 1 de 3 Likebook Muses Motherboard Replacement: étape 3, image 2 de 3 Likebook Muses Motherboard Replacement: étape 3, image 3 de 3
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Motherboard Replacement: étape 4, image 1 de 3 Likebook Muses Motherboard Replacement: étape 4, image 2 de 3 Likebook Muses Motherboard Replacement: étape 4, image 3 de 3
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Motherboard Replacement: étape 5, image 1 de 1
    • The rear cover has been removed.
  6. Likebook Muses Motherboard Replacement, Mainboard: étape 6, image 1 de 3 Likebook Muses Motherboard Replacement, Mainboard: étape 6, image 2 de 3 Likebook Muses Motherboard Replacement, Mainboard: étape 6, image 3 de 3
    • Disconnect the battery.
    • Due to the placement of the battery, the connector may not come out all the way.
  7. Likebook Muses Motherboard Replacement: étape 7, image 1 de 3 Likebook Muses Motherboard Replacement: étape 7, image 2 de 3 Likebook Muses Motherboard Replacement: étape 7, image 3 de 3
    • Using the pointed end of a spudger, disconnect the touch panel.
  8. Likebook Muses Motherboard Replacement: étape 8, image 1 de 3 Likebook Muses Motherboard Replacement: étape 8, image 2 de 3 Likebook Muses Motherboard Replacement: étape 8, image 3 de 3
    • Disconnect the pen input controller.
  9. Likebook Muses Motherboard Replacement: étape 9, image 1 de 3 Likebook Muses Motherboard Replacement: étape 9, image 2 de 3 Likebook Muses Motherboard Replacement: étape 9, image 3 de 3
    • Lift up part of the tape covering the frontlight connector.
    • Using the flat end of your spudger, disconnect the display.
  10. Likebook Muses Motherboard Replacement: étape 10, image 1 de 2 Likebook Muses Motherboard Replacement: étape 10, image 2 de 2
    • Peel the tape the rest of the way
    • Using the pointed end of your spudger, disconnect the frontlight.
  11. Likebook Muses Motherboard Replacement: étape 11, image 1 de 1
    • Remove these screws using your J00 screwdriver (or a PH00 screwdriver if you don't have one).
    • Remove these screws using your PH00 screwdriver.
    • One of these screws has a tamper detection sticker pasted over the screw head.
    • You should be able to poke the screwdriver through it.
  12. Likebook Muses Motherboard Replacement: étape 12, image 1 de 1
    • Lift the mainboard out from the top,
    • The speaker connections are only held in with solder, and may break if you're not careful.
  13. Likebook Muses Motherboard Replacement: étape 13, image 1 de 3 Likebook Muses Motherboard Replacement: étape 13, image 2 de 3 Likebook Muses Motherboard Replacement: étape 13, image 3 de 3
    • The mainboard has been removed.
Kevin Bhasi
Membre depuis le 12/26/14
1 262 Réputation
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 67
