Aller au contenu principal
Linksys WRT54G Motherboard Replacement
Ce dont vous avez besoin
  1. Linksys WRT54G Motherboard Replacement, Antennas: étape 1, image 1 de 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Replacement: étape 2, image 1 de 3 Linksys WRT54G Motherboard Replacement: étape 2, image 2 de 3 Linksys WRT54G Motherboard Replacement: étape 2, image 3 de 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Replacement: étape 3, image 1 de 3 Linksys WRT54G Motherboard Replacement: étape 3, image 2 de 3 Linksys WRT54G Motherboard Replacement: étape 3, image 3 de 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Replacement, Casing: étape 4, image 1 de 2 Linksys WRT54G Motherboard Replacement, Casing: étape 4, image 2 de 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Replacement, Motherboard: étape 5, image 1 de 2 Linksys WRT54G Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Replacement: étape 6, image 1 de 2 Linksys WRT54G Motherboard Replacement: étape 6, image 2 de 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Replacement: étape 7, image 1 de 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
3 autres ont terminé cette réparation.
Aaron Brown
Membre depuis le 10/11/11
163 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-7, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 3,393
