Aller au contenu principal
Introduction
Remove the top cover of the optical drive to access the internals and replace any malfunctioning components.
  1. Insert an open paper clip into the small hole on the left side of the faceplate. After the tray opens, extend it fully.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Pull the faceplate away from the main chassis.
    • Pull the faceplate away from the main chassis.
  4. Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
    • Lift the top and bottom chassis straight up in order to remove them.
2 autre(s) ont terminé cette réparation.
James Biggs
Membre depuis le 12/10/2011
596 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-5, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 membres
3 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 2,531
