Aller au contenu principal
Logitech G502 Lightspeed Battery Replacement
Ce dont vous avez besoin
  1. Logitech G502 Lightspeed Battery Replacement, Switch the mouse off: étape 1, image 1 de 2 Logitech G502 Lightspeed Battery Replacement, Switch the mouse off: étape 1, image 2 de 2
    • Before you begin, flip the power switch into the OFF position.
  2. Logitech G502 Lightspeed Battery Replacement, Heat the mouse feet: étape 2, image 1 de 2 Logitech G502 Lightspeed Battery Replacement, Heat the mouse feet: étape 2, image 2 de 2
    • Heat an iOpener and apply it to the mouse feet for one minute.
    • You may use a hair dryer or heat gun. If you do, set it to the lowest temperature setting and apply heat for 10 seconds.
  3. Logitech G502 Lightspeed Battery Replacement, Remove the front foot: étape 3, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the front foot: étape 3, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the front foot: étape 3, image 3 de 3
    • Insert the tip of an opening pick underneath the front foot at the gap in its recess.
    • The mouse feet are made of two layers. Make sure you insert the pick under the bottom layer to completely remove the foot.
    • When possible, grab with your fingers and slowly pull to peel it off completely.
  4. Logitech G502 Lightspeed Battery Replacement, Remove the front right foot: étape 4, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the front right foot: étape 4, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the front right foot: étape 4, image 3 de 3
    • Insert the tip of an opening pick underneath the tiny front right foot at the gap in its recess.
  5. Logitech G502 Lightspeed Battery Replacement, Remove the rear foot: étape 5, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the rear foot: étape 5, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the rear foot: étape 5, image 3 de 3
    • Insert the tip of an opening pick underneath the rear foot starting at the gap in its recess.
  6. Logitech G502 Lightspeed Battery Replacement, Remove the weight hatch: étape 6, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the weight hatch: étape 6, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Remove the weight hatch: étape 6, image 3 de 3
    • Use your fingers to remove the weight hatch by pulling the bottom part of the thumb rest straight down.
  7. Logitech G502 Lightspeed Battery Replacement, Remove the bottom screws: étape 7, image 1 de 2 Logitech G502 Lightspeed Battery Replacement, Remove the bottom screws: étape 7, image 2 de 2
    • Remove the four 5.4 mm long Phillips screws at the underside of the mouse.
  8. Logitech G502 Lightspeed Battery Replacement, Unclip the bottom plate: étape 8, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Unclip the bottom plate: étape 8, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Unclip the bottom plate: étape 8, image 3 de 3
    • Insert an opening pick between the bottom plate and the upper shell starting at the rear of the mouse.
    • Slide the opening pick along the gap between the two halves towards the outer flank of the mouse.
    • Twist the opening pick to disengage the clips holding both halves together.
    • This might require more force than anticipated.
  9. Logitech G502 Lightspeed Battery Replacement: étape 9, image 1 de 3 Logitech G502 Lightspeed Battery Replacement: étape 9, image 2 de 3 Logitech G502 Lightspeed Battery Replacement: étape 9, image 3 de 3
    • Again insert the tip of an opening pick between the bottom plate and the top shell starting at the rear.
    • Slide the pick along the gap between the two halves towards the thumb rest.
    • Make sure to follow the curved geometry to keep the pick in the gap.
    • Twist the opening pick to unhinge the remaining clips.
    • This also might require more force than anticipated.
  10. Logitech G502 Lightspeed Battery Replacement, Hinge open the top shell: étape 10, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Hinge open the top shell: étape 10, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Hinge open the top shell: étape 10, image 3 de 3
    • Flip the mouse over on its (removed) feet and hinge the top shell open towards the right side.
    • Don’t remove the top shell all the way yet. It is still connected to the bottom plate via cables.
  11. Logitech G502 Lightspeed Battery Replacement, Disconnect the battery: étape 11, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Disconnect the battery: étape 11, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Disconnect the battery: étape 11, image 3 de 3
    • Hold the battery cable close to the connector and carefully "walk it out" by pulling parallel to the motherboard rocking the connector side to side.
  12. Logitech G502 Lightspeed Battery Replacement, Disconnect the interconnect cables: étape 12, image 1 de 3 Logitech G502 Lightspeed Battery Replacement, Disconnect the interconnect cables: étape 12, image 2 de 3 Logitech G502 Lightspeed Battery Replacement, Disconnect the interconnect cables: étape 12, image 3 de 3
    • Use a spudger or your fingernail to flip up the small, hinged locking flap of both ZIF connectors to disconnect and free the interconnect cables.
    • If the cables don’t pop out by themselves use your fingers to lift them out of the sockets.
  13. Logitech G502 Lightspeed Battery Replacement, Loosen the battery: étape 13, image 1 de 2 Logitech G502 Lightspeed Battery Replacement, Loosen the battery: étape 13, image 2 de 2
    • Insert the tip of an opening pick between the battery and its plastic tub.
    • Use an opening pick to pry the battery up slightly to loosen the adhesive underneath.
  14. Logitech G502 Lightspeed Battery Replacement, Get underneath the battery: étape 14, image 1 de 2 Logitech G502 Lightspeed Battery Replacement, Get underneath the battery: étape 14, image 2 de 2
    • Push the opening pick all the way under the battery.
  15. Logitech G502 Lightspeed Battery Replacement, Remove the battery: étape 15, image 1 de 2 Logitech G502 Lightspeed Battery Replacement, Remove the battery: étape 15, image 2 de 2
    • The battery adhesive will now stick mostly to the opening pick.
    • Slowly pull the opening pick towards the rear of the mouse to slide the battery out from under the plastic tab and out of its tub.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape if the battery comes without one. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
18 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
119 191 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 092 tutoriels rédigés
4 commentaires
What type of battery is needed as replacement?
Jonas - Réponse
The battery model is "AHB521630"
Tobias Isakeit -
Very good tutorial !
If you are searching a new battery, Aliexpress is your friend :)
zhorglub - Réponse
Thank u for the Instruction, has take less than 10 Min
Kai Petersen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 36
7 derniers jours : 229
30 derniers jours : 1,034
Total : 30,455
