Aller au contenu principal
Logitech UE Boom Speaker Replacement
Ce dont vous avez besoin
  1. Logitech UE Boom Speaker Replacement, D-ring: étape 1, image 1 de 1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. Logitech UE Boom Speaker Replacement: étape 2, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 2, image 2 de 2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. Logitech UE Boom Speaker Replacement, Bluetooth Adapter: étape 3, image 1 de 1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    This part is not easy. The main risk is to broke the plastics clips.
    Optrolight - Réponse
    Use a heat gun (or hair dryer on high) first around the edges before attempting to pry it open. There are six tabs: one directly in line with the charging port; one approx 3/4 inch to the left and right of that tab; one centered against the back of the volume control "panel", and one approx 3/4 inch to either side of that one. So when prying, try to insert your spudger in between those spacings in order to not push on the tabs directly.
    Lotus Flower - Réponse
  4. Logitech UE Boom Speaker Replacement: étape 4, image 1 de 3 Logitech UE Boom Speaker Replacement: étape 4, image 2 de 3 Logitech UE Boom Speaker Replacement: étape 4, image 3 de 3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. Logitech UE Boom Speaker Replacement: étape 5, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 5, image 2 de 2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom Speaker Replacement: étape 6, image 1 de 3 Logitech UE Boom Speaker Replacement: étape 6, image 2 de 3 Logitech UE Boom Speaker Replacement: étape 6, image 3 de 3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate.
    Great instructions here guys - just one comment from myself - underneath the plate there is glue holding it down as well as the solder joints. Be sure to heat it up slightly prior to lifting out otherwise the capacitors and other components get stuck in the glue.
    Jamie Horn - Réponse
    bei mir sieht der blootooth-adapter anders aus. da muss ich nix löten, er ist klein und liegt nur in einer passenden mulde, aus der er herausgehoben und in die er wieder abgelegt werden kann. meine typbezeichnung ist S-00122.
    thomas propp - Réponse
    Definitely start with the middle one, has 2 solder hinge points that took me a couple minutes to heat up, wiggle and finally lift up. One that side lifted, was much easier to go back to the edge hinge, heat up and just gently pull off.
    Michael Arvan - Réponse
    It is importante to note that there are two large solder hinge points and for the midle to pin point. Easy to desoldering but not easy to soldering after battery replacement.
  7. Logitech UE Boom Speaker Replacement: étape 7, image 1 de 1
    • With the switch plate disconnected, remove it and your device should now look like this.
  8. Logitech UE Boom Speaker Replacement, Lithium Battery: étape 8, image 1 de 1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
  9. Logitech UE Boom Speaker Replacement: étape 9, image 1 de 1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
    Zuerst auf der Gegenseite zuerst den Deckel, dann die Hülle lösen. Erst am Ende die Seite mit dem Power Button.
    Hans Fuchs - Réponse
    Translation: First loosen the cover on the opposite side, then the cover. Only at the end the page with the power button.
    Dan -
    A tips that could be help lot of us. i consider it what not easy to pry the sleeve off. But in fact there are many hole around the side that could be used to push through the holes, the plastic ring retainer.
  10. Logitech UE Boom Speaker Replacement: étape 10, image 1 de 3 Logitech UE Boom Speaker Replacement: étape 10, image 2 de 3 Logitech UE Boom Speaker Replacement: étape 10, image 3 de 3
    • Peel off the sleeve.
  11. Logitech UE Boom Speaker Replacement: étape 11, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 11, image 2 de 2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
  12. Logitech UE Boom Speaker Replacement: étape 12, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 12, image 2 de 2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
  13. Logitech UE Boom Speaker Replacement: étape 13, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 13, image 2 de 2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
  14. Logitech UE Boom Speaker Replacement: étape 14, image 1 de 1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
  15. Logitech UE Boom Speaker Replacement: étape 15, image 1 de 1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
  16. Logitech UE Boom Speaker Replacement: étape 16, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 16, image 2 de 2
    • Remove the battery by pulling it from the terminal as marked in the picture.
  17. Logitech UE Boom Speaker Replacement, Speaker: étape 17, image 1 de 1
    • At this point, you should have the case completely open and removed the battery from the motherboard.
    where do I get the speakers to replace with please
    Amwaj Khamis - Réponse
  18. Logitech UE Boom Speaker Replacement: étape 18, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 18, image 2 de 2
    • Remove the panel covering the speaker with the spudger. Be careful while doing this, as it is a very fragile and brittle metal panel.
  19. Logitech UE Boom Speaker Replacement: étape 19, image 1 de 1
    • Unscrew the bolts holding the speaker in after removing the panel covering the speakers.
  20. Logitech UE Boom Speaker Replacement: étape 20, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 20, image 2 de 2
    • Gently pull the speaker off of the case after unscrewing the screws holding it in place.
  21. Logitech UE Boom Speaker Replacement: étape 21, image 1 de 1
    • Start unscrewing the screws on the second speaker (the process for removing the panels is the same for both speakers!).
  22. Logitech UE Boom Speaker Replacement: étape 22, image 1 de 1
    • Remove the speaker from the casing as was done previously with the other speaker.
  23. Logitech UE Boom Speaker Replacement: étape 23, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 23, image 2 de 2
    • Gently unplug the speaker from the motherboard after removing it from its place in the casing of the device.
  24. Logitech UE Boom Speaker Replacement: étape 24, image 1 de 2 Logitech UE Boom Speaker Replacement: étape 24, image 2 de 2
    • Gently unplug the other speaker from the motherboard after removing it from its place in the casing of the device.
    • After this, you will have completely removed the speakers from the device!
18 autres ont terminé cette réparation.
Andrew Pifferini
Membre depuis le 10/01/15
1 320 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-1, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 membres
22 tutoriels rédigés
16 commentaires
thank you for this excellent tutorial. Would you have an idea where replacement speakers can be found online ?
olivier delannoy - Réponse
Is it necessary to solder the bluetooth adapter because my speaker got dented and now it makes a weird popping sound when i play my music on high volume. i think the problem is that the metal frame is touching the speaker causing the popping sound when the speaker vibrates
Humberto Aponte - Réponse
my speaker have the same problem what should i do?
streetfames -
How many speakers are inside exactly, 2 or 4 ? I didn't understand if there are 2 per side or not...
I don't have sound on a side of my speaker and I don't now if this is normal (it is new)
Pixedy - Réponse
There are 2 speakers and 2 passive resonators, the 2 on the top are speakers while the 2 on the bottom are basically speakers without coils, they are just cones that rely on the pressure and vibration inside of the device generated by the real speakers on top to vibrate themselves and increase bass/low-end presence.
frankg65tg -
My speaker does the same sound wen i play my music loud
urirlperez04 - Réponse
What should I do mine turns on if I tap it and its poppy I think my sister got it wet what should I do
tane jury - Réponse
^But it turns on. I think I need to change the speakers in side it ????
tane jury - Réponse
when i vigorously shake mine something inside shakes too what could be the problem
nathanpace2003 - Réponse
Where do I get replacement speakers from?ive only had mine for 8months but bought on duty free.
Jim mor - Réponse
You should contact UE Support (http://www.ultimateears.com/en-us/suppor...). Your product should have 2 years warranty.
Mario Toller -
Alternatively… STEP 1 buy a new speaker.
Albert Einstein - Réponse
Where can I buy this UE replacement speakers? I have 2 broken.
knknmlambo - Réponse
Where can I purchase speakers for use boom
Brent Reimer - Réponse
My speaker fell on the floor: the battery is 100% and the speaker is ON, speaker is connected to my iPhone via Bluetooth (or via cable), I and can increase and decrease the volume (I'll checked in the app) BUT I have no music sound whatsoever? The speaker has now been completely taken apart, but all cables appear to be connected and nothing looks wrong on the printing board: what could be the problem?
Hans - Réponse
If you get a tone when you hit the volume limit, the issue is upstream of the speaker it’s self and the speakers Amp. This gets into the the DAC logic and the Analog/Bluetooth connection logic. Basically, the logic board has an issue.
Dan -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 57
30 derniers jours : 234
Total : 63,300
