Aller au contenu principal
Logitech UE MegaBoom 3 USB Port Replacement
Ce dont vous avez besoin
  1. Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: étape 1, image 1 de 2 Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: étape 1, image 2 de 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 USB Port Replacement: étape 2, image 1 de 3 Logitech UE MegaBoom 3 USB Port Replacement: étape 2, image 2 de 3 Logitech UE MegaBoom 3 USB Port Replacement: étape 2, image 3 de 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 USB Port Replacement, USB Port: étape 3, image 1 de 3 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: étape 3, image 2 de 3 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: étape 3, image 3 de 3
    • To remove the plastic frame that’s covering the charging board, use a Phillips #0 to remove both 2.4 mm screws.
    • Replace the charging port.
2 autres ont terminé cette réparation.
Anthony Miles
Membre depuis le 09/04/23
1 021 Réputation
6 tutoriels rédigés
Équipe
University of Memphis, Team 1-2, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-2, Sneed Fall 2023
UM-SNEED-F23S1G2
4 membres
7 tutoriels rédigés
3Commentaires sur le guide
Thanks for the guide, this was very helpful!
Jason Doland - Réponse
How easy/hard would it be to upgrade the charging port to usb-c?
Nenad Tarlac - Réponse
This would be nearly impossible because micro-usb and usb type-c use different pinout (different number of pins...) and require different layout of the connection points on the charging PCB. And also the size of the usb-c socket is different.⏎
To do such modification it would require altering the charging PCB board, speaker housing (hole for the charging socket) and jumping (soldering very thin enamelled wires) from the usb-c connector to the different points on the charging PCB board.
Also this wouldn't increase the maximum charging speed, it would just be for the convenience of using one type-c cable with different modern devices.
Simon -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 69
Total : 475
