Introduction
The CPU module is plugged into motherboard connector U1. The module contains the main SoC (System-on-Chip) and memory.
The original release of MNT Reform ships with the Boundary Devices Nitrogen8M_SOM CPU module, however alternative CPU modules are in development, and you can also develop your own
Please note that removing the CPU module will require re-applying thermal paste.
Ce dont vous avez besoin
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Pull out the eight battery cells one by one, and set them aside safely.
Remove the following screws securing the heatsink:
Four M2×12 Philips screws
Outil utilisé dans cette étape :Tweezers$4.99
Gently pull the heatsink up.
Gently lift the black tab on the ribbon cable connector, then slide the ribbon cable out.
Release the tabs on each side of the CPU module by pulling them at the same time.
These tabs lock the module in place and releasing them will cause the module to "pop" up, similarly to a RAM stick on other laptop computers.
To reassemble your device, follow these instructions in reverse order. Don't forget to re-apply new thermal paste.
Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
