Introduction
This guide will show the replacement of the webcam on the MSI Apache Pro 004 laptop.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Start with the bottom of the laptop facing up.
  • Start with the bottom of the laptop facing up.
Ajouter un commentaire
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
  • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
  • Remove the bottom plate
  • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  • Remove the screw holding down the battery with a PH1 screwdriver.
  • Pull out the battery.
  • Flip over the laptop and open it.
  • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
  • You may need to apply some firm pressure to get it started.
  • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  • Locate the WebCam on the middle of the device.
  • Slide a metal opener tool to remove the Webcam
Majid Al Hashmi
Membre depuis le 13/02/2018
265 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 54
