Introduction
This is a member-submitted teardown. iFixit’s teardown of the Mac mini Late 2018 can be found here, and the RAM replacement guide can be found here.
Ce dont vous avez besoin
So here it is, exactly the same form factor as the previous Mac mini, but now in Space Gray
Once flipped over, a familiar black cover is revealed.
Pry open the lid to release it from the three large screws
The lid had a soft foam inside to dampen the vibrations of the beefed up fan
The lid is secured with the same TR6 screws as the 2014 model
The antenna cable is very short, so watch out; rotate the cover to reveal the internals
The antenna cable is held down with a little TX6 screw
It has a tiny washer to make sure no stress is applied to the cable
The fan has four identical TX6 screws holding it down
The screws go trough a rubber tube to reduce vibration
Underneath the fan the connector pops off easilly
The fan feels solid. Much better than previous models
Now, lets take out the motherboard
Massive (for the mini) TX10 screws secure the motherboard to the chassis
Slide the motherboard out by gently applying pressure to the heatsink
Some interesting design choices made here. A full size CMOS battery
The wifi wiring runs underneath the large speaker
The power button is attached to a ultra flat cable that runs in an arc along the heatsink
We flip over the motherboard to see a massive amount of tiny components
Also some familiar pieces of foam all over the place
But now what we are all here for. The RAM
Four TX5 screws holt it down
These rubber parts will be a pain to put back on later.
There are tiny pieces of rubber in it that need to slide into the metal clips holding the memory in place
The memory itself sits upside down in its sockets
The springs are very strong and will shoot the memory in your face if you're not careful!
The power supply is secured in a similar way as with the previous models
A little clip has to be removed, and the connector can be rotated
The power supply is held down with three TX6 screws
They look just like the fan screws, but they appear just a little bit thicker and with longer thread
After taking out the power supply we are left with an empty shell
I really enjoyed taking this mini apart. My verdict is it's much easier than the 2014 model as cables are in a more logical place
7 autres ont terminé cette réparation.
6 commentaires
What happens to the machine if the SSD fails? Will the entire logic board need to be replaced? I have a feeling that the chances of SSD failing would be significantly higher than Ram… So shouldn’t apple make SSD removable as well?
Failing SSD means a failing motherboard. In my experience, apple ssd-s are very reliable. Upgradable memory allows you to use a device longer. If you configure it with 16GB today, you might want to max out the memory in the future, once prices go down.
I didn’t have the courage to take the heatsink off. So we’ll have to wait for someone who does.
Mich würde interessieren, wie die CMOS Batterie getauscht wird, bzw. welcher Typ es ist.
