Introduction
Use this guide to replace a damaged heat sink or its thermal paste.
Ce dont vous avez besoin
Outil utilisé dans cette étape :P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
8 autres ont terminé cette réparation.
1 commentaire de tutoriel
Hello. When I tried to reinstall the IO board, I noticed that the sounds werent detected. The microphone too. The connectors were installed. Then when i plug the magsafe charger, power source is power adapter, but not charging. The USB port doesnt detect any flashdrives.
What may seem to be the problem and how can I fix it? Thank you. I’m on my last 80% battery life. Please help.
