Aller au contenu principal
MacBook Core 2 Duo RAM cover replacement
Ce dont vous avez besoin
  1. MacBook Core 2 Duo RAM cover replacement, RAM cover: étape 1, image 1 de 1
    • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
    • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
    • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
    • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
  2. MacBook Core 2 Duo RAM cover replacement: étape 2, image 1 de 1
    • Pull the L-shaped RAM cover towards you and remove it from the laptop.
To reassemble your device, follow these steps in reverse order.
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
jp en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Uhucream
Membre depuis le 10/04/15
797 Réputation
2 tutoriels rédigés
Équipe
Japanese Translators Membre de l'équipe Japanese Translators
Community
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 1,316
