Introduction
Does your MacBook's music sound not quite right—or, rather, not right at all? Restore balanced sound to your laptop by replacing the right speaker.
Pièces
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
Remove the following 4 Phillips screws:
Three 3 mm Phillips securing the subwoofer and right speaker to the lower case.
One 7.5 mm Phillips securing the loop in the display data cable to the lower case.
5 autre(s) ont terminé cette réparation.
