Aller au contenu principal
MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement
Ce dont vous avez besoin
  1. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Tools: étape 1, image 1 de 1
    • Loctite super-glue remover, to remove any superglue residue, be careful its like water.
    • Loctite super-glue, for sticking down the clips.
    • A toothpick to spread the glue. You need something long and thin. Please avoid metal if possible.
  2. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Check if the space is working: étape 2, image 1 de 1
    • Clean the middle mechanical bit with a cloth to make sure that it is working when you place the peg in.
    • Ignore the superglue if you see it, that was removed later on.
    • Use a dry kitchen towel and rub over the gold mechanical bits, then place the middle clip.
    • Don't glue it yet, this is just to check that the space function is working.
    • Open up Word and see if the spacebar works.
  3. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Positioning the hinges correctly: étape 3, image 1 de 1
    • It Should look like this.
    • The top part of the hinges should have a slightly bigger gap for the silver bars, the bottom gap is in the lower left.
  4. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Placing the hinge: étape 4, image 1 de 1
    • Simple step, just place in the hinge... properly
  5. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Right Clip: étape 5, image 1 de 1
    • Only use a seriously small amount of glue. place in 2 dots and spread it with a pencil etc. something long and thin.
    • Make sure you spread it enough like I did, this can effect the space-bar when pressing,
    • The orange highlighted bit is the amount of glue I used.
  6. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Left clip: étape 6, image 1 de 1
    • Now do the exact same for the left-clip. You only need a little bit of glue, and make sure you spread it left & right.
  7. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Middle Peg, be careful its facing the correct way.: étape 7, image 1 de 2 MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Middle Peg, be careful its facing the correct way.: étape 7, image 2 de 2
    • Make sure that the middle-peg is in the correct direction, at the back is a "U" like symbol, it needs to be facing down.
    • Now when placing in the middle-clip, only apply small dots of glue in each corner and do-not spread it.
    • Then place on-top, the middle-clip, make sure its facing the right way.
  8. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Placing the Spacebar: étape 8, image 1 de 1
    • This part is tricky.
    • First clip in the bottom 4 hooks like I did, and then you're going to close it likes its a book.
  9. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Pushing the spacebar in: étape 9, image 1 de 1
    • Push in where I have drawn in the yellow arrows, you should hear 4 clicks.
    • Push each clip in 1 by 1.
I’m not paying apple or another local repair store £500 to repair this. And neither should you, keep trying until successful, it’s very easy when you know what you’re doing/screwed up alot.
thanks for reading
4 autres ont terminé cette réparation.
Amnesi4c
Membre depuis le 07/29/20
253 Réputation
1 tutoriel rédigé
5 commentaires
JE n'y arrive pas
il faut coller quoi
albert - Réponse
Bonjour, J'écrisavec monclavier défectueux. Donc pas d'espaces :) après avoir cru que j'avaisun pc bienrobuste j'ai tentédetout démonter ettadammm j'ai tout cassé. Jevais suivre votretuto qui àl'air fortbien expoliqué. Jecommande ensuivantvoslien après avoir eu aussi un devis à490 eurosXD
Je reviendraiici,si letexteestlisible,c'estqueçaauramarché !!!
lampion - Réponse
Alors non...c'est un chouette tuto mais ça nemarchepas. Aucun rebond. Je nesaispascequia foiré mais ça m'énerve fort
lampion - Réponse
@vivianelampion Je suis désolée d'apprendre que votre réparation n'a pas marché. Je vous conseille de poser une question sur notre Forum, afin que les autres membres de la communauté puissent vous aider à résoudre votre problème. Bonne chance !
Claire Miesch -
Merci à tous, j'ai réussi ça marche super bien! J'ai cassé en deux une des deux pièces transparentes, attention au milieu c'est super fragile. Je l'ai collé quand même et ça marche très bien, j'ai commencé par coller les autres pièces et j'ai collé la cassé à la fin. Quel satisfaction !
Gabriel Danet - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 55
30 derniers jours : 274
Total : 6,219
