Aller au contenu principal
Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011
Ce dont vous avez besoin
  1. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les dix vis suivantes :
    • Trois vis Phillips #00 14,4 mm
    • Trois vis Phillips #00 3,5 mm
    • Quatre vis à épaulement Phillips #00 3,5 mm
    • Quand vous replacerez les petites vis, alignez-les perpendiculairement à la légère courbe de la coque (elles ne se vissent pas à la verticale).
    How much weight can I save by removing the optical drive?
    gunes314 - Réponse
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - Réponse
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - Réponse
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - Réponse
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - Réponse
    A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
    Iain Boyd - Réponse
    I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
    cam2000deluxe -
    Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
    Patrick Langvardt - Réponse
    That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
    Gary Register -
    Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
    Degeorges - Réponse
    Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
    Claire Miesch -
    Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
    Moritz - Réponse
    Funny, it's not her hands that are doing the close ups. :)
    Cinemated Man - Réponse
    What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
    MLNLRD - Réponse
  2. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 2, image 1 de 2 Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 2, image 2 de 2
    • Faites levier avec vos doigts au niveau de la fente pour sortir le boîtier inférieur de la coque du MacBook.
    • Retirez le boîtier inférieur.
  3. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011, Connexion de la batterie: étape 3, image 1 de 2 Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011, Connexion de la batterie: étape 3, image 2 de 2
    • À l'aide de l'extrémité d'une spatule (spudger), faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    • Il convient d'appliquer l'effet de levier sur les deux côtés courts du connecteur. Faites attention aux coins des connecteurs, car ils se cassent facilement.
    Is this step of removing the battery connector required?
    manodh - Réponse
    yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
    khull -
    Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
    aekinaka - Réponse
    Be patient on disconnecting this one. It worked for me step by step, little by little.
    Phil Wagner - Réponse
    I used the nails of thumb and pointer finger simultaneously - worked pretty fine
    Reinhard Kaune - Réponse
    I whittled down ends of two wooden strips to use, along with my fingernails to start with. I used halves of a wooden clothespin, but popsicle sticks should work too.
    Mike Baker - Réponse
  4. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 4, image 1 de 1
    • Repliez légèrement le câble de la batterie vers l'arrière pour éviter qu'il ne se reconnecte accidentellement à la prise sur la carte mère pendant que vous travaillez.
    I put some tape between the connector and socket while working on the drive.
    Stephen Smith - Réponse
    That's a good tip
    Anrothan -
    Great tip, I did that too
    Ahmed Mahran -
    One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
    lelandjordon - Réponse
    On my MacBook Pro, the connector seems to be an integral part of the battery.
    Jerry South - Réponse
    I suspect it’s just like the special screwdriver required for seatbelts on cars – to discourage regular consumers from attempting repairs. Of course, this only encourages consumers to use the wrong tool to attempt to repairs
    colleenthompson - Réponse
    Dissambling my MacBookPro Premium Mid 2012 (i5-3210M 2.5Ghz) was easily, Careful with the screws, use screwdriver fitting exactly with the screws, you damage them very fast. Work very exactly, relaxed with time, consentration, good Tools and with feelings in your hands. Disconnect the Akku was easy if you take care, remove it to be safe, Two screws more, more space to work & haven`t to think about damaging someting. Apple use diffrent screws, you should have many difffrent scewdrivers. It is also good to clean everything inside, With time everything gets very dusty & dirty, don`t forget the sides and little fittings at the case. Use a pinsel, alcohol, soft peace stuff, it will look like new. If you have knowledge & experience, you can paint it in any colour or airbrushing for individualizing. You can also just polish it with a soft Politure (Sonax car Polish No1, NOT with wax or take an other light Politure you familiar & can do the job, A Laptop should serviced once a year, keeping it good working over years
    Stefan Lindner - Réponse
    First thing i do is open & cleanig everything inside,specially the cooling & fan, renew the thermal paste with an high quality product. Install the Nain System, clean up Bloatware and other unnecessary things, install standard software for daily use, additional change system components against better one (Edge to Firefox, Windows Media Player to VLC , an Office Suite and configuring everything for Data Protection, Privacy- & Indentety Protection, install Drivers from the component Manufactur (incedible effect, disable limitations, more functions, work better & faster, increasing performance, additional change the WiFi & Bluetooth Card to a better one a UMTS WWAN to an LTE Card, increase RAM with two Dual-Channel working SODIMMs, Use M2 or 2,5" SSD if no M2 Slot aviable) as System- and Software iDrive, a FAT32 formatted 32GB Partition to be safe of metaviruses comes with harmless downloads, and a big 2,5 HDD to store the user data. What does you guys think about this? Old Computer become a new life,
    I livein Austria, near Vienna, if someone needs help or anything else, i would be glad to help. I always searching old or broken devices to bring them to new live. I also searching for spare parts, specilly a Bottom & Side Case and a 256GB or higher NGFF Storage Card for a Sony Vaio Tab 11 SVT1144HE (2014), some 14,1" Displays for a HP Probook 440G5 (2016), Elitebook MT 43 Mobile Thin Client, (2011), Dell Vostro 3460 (2012) Lenovo Thinkpad T440s (2014), and a Logic Board for an Lenovo Ideapad 330-15ARR (2017, damaged by Water i think) and a Logic Bord for an Alienware 17R4 with i7-6870HX & Nvidia 1080 (2018, CPU dead, maybe there is a repair Guide or workaround to bring it back to Life). I need always 8GB or 16GB DDR3 and DDR4 RAM Storage (perfectly two ident one for Dual-Channel use for Laptops, M2 SATA 6GB/s and NVMe PCIe SSDs 500GB or more and 2,5"SSD or HDD with 1TB or more and 3,5" HDD with 4GB or above. If you have some of this or other useful parts and doesn`t need them, please make me an offer, maybe
    2
    an change something you need. This is not a Business what i do, it`s more a Hobby with challenging new Excercices.. Thats the best Point. Plase forgive me as a Newbie this very long Post in the wrong Section, but if you are start writing you cannot stop.... But now i have to come to an end and would be happy if someone wants to get in contact. My E-Mail is: udontknowme@gmx.at (the adress name is just a notice against Big Data and for Privacy Protection!
  5. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011, Ensemble AirPort/Bluetooth: étape 5, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur de la nappe AirPort/Bluetooth pour le débrancher de sa prise sur la carte mère.
    N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
    Greg - Réponse
  6. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 6, image 1 de 1
    • Tirez soigneusement la nappe de la caméra hors de sa prise sur la carte mère.
    • Tirez sur la nappe parallèlement à la surface de la carte mère. Tirer vers le haut peut endommager la carte mère ou la nappe même.
    Be extremely careful on step 6 with late 2011 model unibody macbooks! The cable is connected very tightly to the board and has a great chance of ripping if you just pull the cable.
    Tim Rauls - Réponse
    My cable is broken, have the part number or code to buy?
    VÍCTOR RIFFO - Réponse
    I found there was plenty of length in the camera cable (as it goes around two sides of the optical drive) so does not need to be disconnected - just ease it out of the slot alongside the drive and lay it diagonally across.
    Nic Blinston - Réponse
  7. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 7, image 1 de 2 Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 7, image 2 de 2
    • Poussez soigneusement la nappe AirPort/Bluetooth de côté lorsque vous décollez la nappe de la caméra de la bande adhésive qui la fixe au caisson de basse et au support AirPort/Bluetooth.
    • Retirez la nappe de la caméra, placée sous un dispositif de retenue moulé dans le support AirPort/Bluetooth.
    Take a few phone close-ups of this corner of your system prior to disassembly. Extra photos really help during reassembly.
    airshack - Réponse
  8. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 8, image 1 de 2 Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 8, image 2 de 2
    • Avec la pointe d'une spatule (spudger), soulevez le connecteur de l'antenne la plus proche de la carte mère pour le débrancher de sa prise sur la carte AirPort/Bluetooth.
    • Retirez le câble d'antenne placé sous un dispositif de retenue moulé dans le support AirPort/Bluetooth.
  9. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 9, image 1 de 2 Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 9, image 2 de 2
    • Appliquez la même méthode que dans l'étape précédente pour déconnecter les trois autres connecteurs d'antenne.
    • Retirez leurs câbles des fentes dans le support AirPort/Bluetooth.
    I found re-attaching these antennae connectors the trickiest bit by far as they appear very delicate and seating them correctly was fiddly. In the end lighting them from the side with a small torch helped to check their position before gently pushing them down. The first one made a clicking sound as it connected, the other two went on silently. MBP wifi working perfectly now. I’m fairly sure that was at least £100 of labour had I taken it in for repair so thanks ifixit for saving me money and for the warm glow of accomplishment!
    Andrew - Réponse
    Actually, on my repair attempt, one antenna cable broke (on the image the bottom right one in the red square), I’m not sure whether it broke already before or was morbid somehow. Fact is. suddenly I had this cable in my fingers, and was sure I completely broke the macbook and need to find a new display now.
    But as it turned out: the Mac is still fully working, including WIFI, BT, Camera etc. So apart from my huge relief, I want to address that these cables may break easily at their connection with the display. And that one antenna might be not mandatory for WIFI to work.
    huedrant - Réponse
    How do I know which of these cables goes in which slot when attaching the new display?
    BellaVulpa - Réponse
  10. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 10, image 1 de 1
    • Dévissez les cinq vis suivantes :
    • Deux vis cruciformes de 10,3 mm
    • Deux vis cruciformes de 3,1 mm
    • Une vis cruciforme de 5 mm
  11. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 11, image 1 de 1
    • Soulevez l'ensemble AirPort/Bluetooth et le caisson de basse au niveau du milieu du côté du lecteur optique jusqu'à qu'ils se séparent l'un de l'autre.
  12. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 12, image 1 de 1
    • Ôtez l'ensemble AirPort/Bluetooth en évitant que le contact fragile de l'antenne ne touche le coin du boîtier supérieur.
  13. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011, Carte AirPort/Bluetooth: étape 13, image 1 de 1
    • Retirez le morceau de ruban EMI qui recouvre le connecteur du câble AirPort/Bluetooth.
    once you peel the emi tape off it you might not be able to put it back on
    Francisco Cortes - Réponse
  14. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 14, image 1 de 2 Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 14, image 2 de 2
    • Utilisez la pointe d'un spudger pour soulever le connecteur de la nappe AirPort/Bluetooth de sa prise sur la carte AirPort/Bluetooth.
    • Retirez la nappe AirPort/Bluetooth.
    Hi, any one know the name or the number part of the female connector of the flex cable? (the one on the card)
    Carlo Barrak - Réponse
  15. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 15, image 1 de 1
    • Continuez à décoller le ruban EMI du bas du support AirPort/Bluetooth et retirez-le de l'ensemble.
  16. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 16, image 1 de 1
    • Retirez les trois vis cruciformes de 3 mm fixant la carte AirPort/Bluetooth à son support.
  17. Remplacement de la carte AirPort/Bluetooth du MacBook Pro 13" Unibody fin 2011: étape 17, image 1 de 1
    • Retirez la carte AirPort/Bluetooth de son support.
    • Veillez à ne pas endommager le tampon thermique rose attaché au support.
    Why doesn't the replacement bracket come with a thermal pad, or maybe I didn't see a hint to buy one too?
    Ralf Häuser - Réponse
    Why doesn't the bracket come with a thermal pad or a hint to buy one?
Pour remonter votre appareil, suivez ces instructions en sens inverse.
35 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Phillip Takahashi
Membre depuis le 08/22/11
86 752 Réputation
87 tutoriels rédigés
2 commentaires
Hallo,
Ist das quasi Plug & Play oder muss man hier im Nachhinein noch etwas machen? Ich habe ein MacBook Pro Late 2011 und habe bereits Ventura oben (mit Open Core Legacy Patcher). Das Continuity Activation Tool läuft bei mir nämlich nicht unter Ventura. Das habe ich schon versucht.
David Raff - Réponse
Hallo David, ja, normalerweise ist das schon einfach Plug & Play. Aber: ich kann dir nicht sagen, ob das auch der Fall ist, wenn du eine offiziell nicht mehr unterstützte macOS Version gepatcht hast. Und wenn ich deine Frage richtig verstehe, willst du dein MacBook mit einer neueren Karte ausrüsten, damit Continuity funktioniert? Ob diese Karte überhaupt funktioniert, kann ich dir nicht beantworten.
Fabian Neidhardt -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 69
Total : 30,940
