Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement
Ce dont vous avez besoin
  1. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement, Battery: étape 1, image 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement, RAM Shield: étape 2, image 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    Demander à FixBot
  3. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 3, image 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Demander à FixBot
  4. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement, Upper Case: étape 4, image 1 de 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    Demander à FixBot
  5. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 5, image 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Demander à FixBot
  6. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 6, image 1 de 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
    Demander à FixBot
  7. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 7, image 1 de 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
    Demander à FixBot
  8. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 8, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
    Demander à FixBot
  9. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 9, image 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
    Demander à FixBot
  10. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 10, image 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Demander à FixBot
  11. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement, Optical Drive: étape 11, image 1 de 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
    Demander à FixBot
  12. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 12, image 1 de 1
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
    Demander à FixBot
  13. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 13, image 1 de 1
    • Lift the optical drive up and out of the computer.
    Demander à FixBot
  14. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement, Logic Board: étape 14, image 1 de 1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
    Demander à FixBot
  15. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 15, image 1 de 1
    • Disconnect the iSight and display data cables from the logic board by sliding the cables out of their connectors, removing tape as necessary.
    Demander à FixBot
  16. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 16, image 1 de 1
    • Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
    Demander à FixBot
  17. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 17, image 1 de 1
    • Remove the silver T6 Torx screw securing the ground loop in the display data cable to the casing.
    Demander à FixBot
  18. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 18, image 1 de 1
    • Remove the single T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
    • Lift the clear plastic shield off the right ambient light sensor.
    Demander à FixBot
  19. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 19, image 1 de 1
    • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
    Demander à FixBot
  20. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 20, image 1 de 1
    • Remove the following 15 screws:
    • One 4.4 mm black Phillips screw to the right of the ram slot.
    • Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
    Demander à FixBot
  21. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 21, image 1 de 1
    • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
    • Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
    Demander à FixBot
  22. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 22, image 1 de 1
    • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    • Remove the right fan from the computer.
    Demander à FixBot
  23. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 23, image 1 de 1
    • Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
    Demander à FixBot
  24. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement: étape 24, image 1 de 1
    • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
    • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
    Demander à FixBot
  25. MacBook Pro 15" Core 2 Duo Model A1211 Left Thermal Sensor Replacement, Left Thermal Sensor: étape 25, image 1 de 1
    • Peel back the orange Kapton tape covering the left thermal sensor.
    • Use a spudger to pry the left thermal sensor off the heat sink.
    Demander à FixBot
3 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 36
Total : 10,074
