Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement
Ce dont vous avez besoin
  1. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Battery: étape 1, image 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Memory Door: étape 2, image 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
    Demander à FixBot
  3. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 3, image 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Demander à FixBot
  4. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Upper Case: étape 4, image 1 de 1
    • Remove the two Phillips screws in the battery compartment near the latch.
    Demander à FixBot
  5. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 5, image 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Demander à FixBot
  6. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 6, image 1 de 1
    • Remove the four Phillips screws on the port side of the computer.
    Demander à FixBot
  7. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 7, image 1 de 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
    Demander à FixBot
  8. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 8, image 1 de 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
    Demander à FixBot
  9. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 9, image 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
    Demander à FixBot
  10. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 10, image 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Demander à FixBot
  11. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Optical Drive: étape 11, image 1 de 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
    Demander à FixBot
  12. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 12, image 1 de 1
    • Remove the following 3 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.8 mm black Phillips screw at the top right corner of the drive.
    • The 4.8mm screw may be a T6 Torx
    Demander à FixBot
  13. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 13, image 1 de 1
    • Lift the optical drive up and out of the computer.
    Demander à FixBot
  14. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Logic Board: étape 14, image 1 de 1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
    Demander à FixBot
  15. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 15, image 1 de 1
    • Disconnect the eight indicated connectors from the logic board, removing tape as necessary.
    Demander à FixBot
  16. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 16, image 1 de 1
    • Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
    • Slide the left ambient light sensor cable to the left and out of its connector.
    Demander à FixBot
  17. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 17, image 1 de 1
    • Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
    Demander à FixBot
  18. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 18, image 1 de 1
    • Remove the single silver T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
    • Lift the clear plastic shield off the right ambient light sensor.
    Demander à FixBot
  19. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 19, image 1 de 1
    • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
    Demander à FixBot
  20. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 20, image 1 de 1
    • Remove the following 16 screws, moving cables as necessary:
    • One 4.4 mm black Phillips screw to the right of the RAM slot.
    • Nine 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
    Demander à FixBot
  21. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 21, image 1 de 1
    • Move the display data cable to the right, removing tape as necessary.
    • Peel up and remove the orange foil shield near the right speaker.
    Demander à FixBot
  22. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 22, image 1 de 1
    • Rotate the speaker clockwise approximately 30 degrees until it comes free from the logic board.
    Demander à FixBot
  23. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 23, image 1 de 1
    • Peel up the gray and black speaker wires from the top of the logic board, removing tape as necessary.
    Demander à FixBot
  24. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 24, image 1 de 1
    • Peel up the iSight and inverter board cables from above the left fan.
    • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
    • Place the fan above the Airport card. It is not necessary to entirely remove the fan from the computer.
    Demander à FixBot
  25. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 25, image 1 de 1
    • It may be helpful to hold the heat sink in place while removing the right fan.
    • Lift the right fan up while carefully peeling up the tape which secures the fan to the heat sink.
    • Remove the right fan from the computer.
    Demander à FixBot
  26. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 26, image 1 de 1
    • Lift up the left side of the logic board and disconnect the multi-colored power cable from the bottom of the board.
    Demander à FixBot
  27. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 27, image 1 de 1
    • The logic board is still attached to the computer by one more cable, so don't lift the logic board too far out of the computer yet.
    • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
    • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound from the chips on the back of the logic board. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
    Demander à FixBot
  28. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement: étape 28, image 1 de 1
    • Disconnect the right thermal sensor cable from the bottom of the logic board near the DVI port.
    Demander à FixBot
  29. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Left Thermal Sensor: étape 29, image 1 de 1
    • Peel back the orange Kapton tape covering the left thermal sensor.
    • Use a spudger to pry the left thermal sensor off the heat sink.
    Demander à FixBot
  30. MacBook Pro 15" Core Duo Model A1150 Heat Sink Replacement, Heat Sink: étape 30, image 1 de 1
    • Lift the heat sink out of the computer.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Demander à FixBot
20 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
2 commentaires de tutoriel
I put everything back after replacing the thermal paste in 3 places on the heatsink, but now I have no apple logo on the
display or sound on bootup … what did I miss this time?
Mario da Silva - Réponse Partager
Finished this with the guide laptops running a lot cooler now!
Brent Haynes - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 60
Total : 40,717
