Aller au contenu principal
MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement
Ce dont vous avez besoin
  1. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Lower Case: étape 1, image 1 de 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 2, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 2, image 2 de 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Battery: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    J'achète
    • Remove the two 5-Point Pentalobe screws along the top edge of the battery.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 4, image 1 de 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
  5. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 5, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 5, image 2 de 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 6, image 1 de 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation.
  7. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Hard Drive: étape 7, image 2 de 2
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
    • Lift the the retaining bracket out of the upper case.
  8. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 8, image 1 de 1
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  9. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 9, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement: étape 9, image 2 de 2
    • Remove the hard drive cable by pulling the hard drive straight away from the connector. Keep the connector steady. If pulled by the connector, it can be pulled too far and accidentally tear the hard drive cable.
  10. MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Hard Drive: étape 10, image 1 de 2 MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement, Hard Drive: étape 10, image 2 de 2
    • Remove two T6 Torx screws from each side of the hard drive (four screws total).
    • You'll need to transfer these screws to your new hard drive if you're changing drives.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
208 autres ont terminé cette réparation.
13 commentaires
Piece of cake! Didn't have the 5-point, so I left the battery alone. Finder says I have 550G of free space!
bgranquist - Réponse
Very Easy. Don't need to remove the battery.
Evy Raelison - Réponse
seriously the easiest repair I have done on one of my computers. My biggest worry was getting OS X reinstalled, but iFixIt made that easy as well. Can't believe a local shop wanted $300+ to do this. I spend just over $100 and got my computer back up and running myself.
sopaw22 - Réponse
Hi. Does myy macBook Pro (15" Mid 2009) support Solid State Drive? I upgraded the memory with 8 gigabites, but it´s still a bit slow. I hope someone can answer soon.
Fernando Beltran - Réponse
Yes you can. Look up crucial.com
kris -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 87
Total : 195,439
