Introduction
You can install hard drives up to 9.5mm thick.
Pièces
- 250 GB SSD
- 500 GB SSD
- 1 TB SSD
- 500 GB SSD Hybrid 2.5" Hard Drive
- 500 GB 5400 RPM 2.5" Hard Drive
- 1 TB 5400 RPM 2.5" Hard Drive
- MacBook Pro 17" (Model A1151) Hard Drive Cable
- MacBook Pro 17" (Models A1212 A1229) Hard Drive Cable
- MacBook Pro 17" (Model A1261) Hard Drive Cable
- MacBook Pro 17" (Models A1212/A1229/A1261) Hard Drive Bracket
- Universal Drive Adapter
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Peel up the orange ribbon cable taped to the top of the hard drive. This cable is still connected to the hard drive, so you will only be able to lift up on the cable a little.
Remove the two silver T6 Torx screws and white (or black) rubber bumpers from the right side of the hard drive.
613 autre(s) ont terminé cette réparation.
13 commentaires
On my A1212, all four rubber bumpers were attached to the hard drive.
While this is listed as moderate difficulty, I think it's on the easy side of moderate. If you're used to replacing PC parts, it won't be a problem. Worst problem is dealing with tiny screws with my big hands. I used SuperDuper to clone the drive before swapping.
Actually the tools you only need are the T6-Torx and the Phillips screwdrivers. Everything else is optional for this operation. By the way: thank you, for the guidance! :)
Excellent guide. For anyone who's replaced PC parts before the job is a piece of cake. Tip: Use a muffin tin to put the screws from each step in a different muffin hole in order. Easy to reassemble. I used SuperDuper to clone the new drive.
