Aller au contenu principal
Installation du boîtier inférieur dans le MacBook Unibody modèle A1342
Ce dont vous avez besoin
  1. Installation du boîtier inférieur dans le MacBook Unibody modèle A1342, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les huit vis Phillips 4 mm par lesquelles le boîtier inférieur est fixé au MacBook.
    According to this page http://support.apple.com/kb/HT1651?viewl..., the 8 screws are not identical.
    Can anybody tell me where each kind of screw is supposed to go?
    Gregoire - Réponse
    They are all 100% Identical. You were probably looking at a different model, or Apple has entered the wrong information... Hey, It happens...
    Owen Davies -
    The screws on the Late 2009 are identical. The blue lock compound might make tightening some require a little more effort.
    svenaustx - Réponse
    Can I replace it with a SATA 3 cable?
    nm - Réponse
    A1342 macbook does not have the right controller to support sata III
    Owen Davies -
    hi, i just got back from the apple store and they are really keen for me to upgrade to a new laptop since my battery is old and the screen is cracked, so glad i found ifixit i would love to upgrade this puppy! gonna make it a real sleeper! styler hall wrote about sticking 16 gb of ram in his a 1342 ? is this a simply mather of ordering 3 4gb sticks ?aslo i currently have 4 gb and would like to upgrade to 8 ( or indeed 16) does that mean i need to buy all new sticks or can i continue to use the old one and stick a new one next to it ?
    thanks again mick van aar, perth western aus.
    michelvanaar - Réponse
    The A1342 will take up to 16 GB of RAM, however, there are only two RAM slots, so use two 8-GB RAM modules. Other World Computing (OWC) is a great reference source for info on exactly which RAM to use with which model; prices are usually much better on EBay though. Add an SSD from OWC and your machine will really scream!
    I hope that helps!
    gdesbrisay -
    Gregoire is right. The 8 screws are absolutely NOT identical, I’m looking at them right now, weeowey weeowey.
    John Guzman - Réponse
    I just wanted to say that, in 2020, i used these instructions to replace the magsafe socket on my A1286, mid-2012, pre-Retina MacBook Pro. The internal layout is not quite the same but close enough for me to do the job. I skipped the steps of fully disconnecting the fans and speakers because of what others had said about breaking the sockets. it just meant I had to be extremely careful when lifting up the main board so that I did not tear and break the connections. I was able to disconnect the old magsafe socket with the board flat and in situ, but there was no where near enough room to be able to aline and press home the new par home. Reluctantly i had to lever up the board. This was difficult as there is a tapped post that holds a screw in the way close to where the USB sockets are, that prevented the board lifting up and out. I had to be quite forceful to manouevre the sockets out from the edge of the case.
    Paul Burridge - Réponse
  2. Installation du boîtier inférieur dans le MacBook Unibody modèle A1342: étape 2, image 1 de 3 Installation du boîtier inférieur dans le MacBook Unibody modèle A1342: étape 2, image 2 de 3 Installation du boîtier inférieur dans le MacBook Unibody modèle A1342: étape 2, image 3 de 3
    • Le boîtier inférieur est construit en aluminium avec un revêtement en caoutchouc. Ne pliez pas trop l'aluminium lors du retrait, car une déformation permanente générerait des problèmes de tolérance après le remontage.
    • Soulevez légèrement le boîtier arrière au niveau de la fente.
    • Continuez à faire courir vos doigts entre les boîtiers inférieur et supérieur jusqu'à ce que le boîtier supérieur se dégage des clips de fixation.
    • La position de ces trois clips est indiquée dans la troisième photographie.
    Do the retaining clips have to be re-engaged when replacing the lower case?
    John Morley - Réponse
    Answering my own question, the clips re-engage when the lower case is correctly positioned. You can help them by gently pressing the lower case with your thumbs midway along the two short sides. When everything is correctly aligned the eight screw holes line up.
    John Morley -
    Rather than running your fingernail down the sides to free up the retaining clips, I found that using an old credit card, inserted about 1/4”, to run along the left and right side popped those end retaining clips right off with no problem. You may need to twist the card slightly when in the middle area to help pop those off.
    bdahl385 - Réponse
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
74 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Réponse
Would the Macbook Pro back cover also fit this?
wow - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 52
Total : 69,724
