Aller au contenu principal
Magic Trackpad Battery Replacement
Ce dont vous avez besoin
  1. Magic Trackpad Battery Replacement, Batteries: étape 1, image 1 de 2 Magic Trackpad Battery Replacement, Batteries: étape 1, image 2 de 2
    • Use a spudger or coin to twist out the battery door.
  2. Magic Trackpad Battery Replacement: étape 2, image 1 de 1
    • Slide out the two AA batteries.
3 autres ont terminé cette réparation.
Ronnie
Membre depuis le 10/22/12
3 522 Réputation
5 tutoriels rédigés
4 commentaires
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - Réponse
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - Réponse
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz -
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 29
30 derniers jours : 115
Total : 12,854
