Introduction
This guide shows how to remove and replace the chain tensioner module in a Makita chainsaw.
Optional Tools:
- Chainsaw scrench
Ce dont vous avez besoin
Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
Remove the four 12 mm long T27 screws securing the chain brake cover.
Twist the tension screw clockwise until the slide bar stops at the right end.
Remove the single 15.7 mm long T27 screw holding the chain tensioner assembly in place.
Lightly lubricate the packing ring and press it into the back of the adjustment screw.
5 autres ont terminé cette réparation.
