Aller au contenu principal
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: étape 1, image 1 de 1
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
  2. Maquet Servo-U O2 Supply Replacement: étape 2, image 1 de 1
    • Lower the locking catch.
  3. Maquet Servo-U O2 Supply Replacement: étape 3, image 1 de 2 Maquet Servo-U O2 Supply Replacement: étape 3, image 2 de 2
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
  4. Maquet Servo-U O2 Supply Replacement: étape 4, image 1 de 1
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
  5. Maquet Servo-U O2 Supply Replacement: étape 5, image 1 de 1
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
  6. Maquet Servo-U O2 Supply Replacement: étape 6, image 1 de 1
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
Ligne d'arrivée
Cassandra Aarrestad
Membre depuis le 01/23/20
627 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S7-G2, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 37
Total : 2,112
