Aller au contenu principal
Marshall Stanmore II Rear Panel Replacement
Ce dont vous avez besoin
  1. Marshall Stanmore II Rear Panel Replacement, Rear Panel: étape 1, image 1 de 2 Marshall Stanmore II Rear Panel Replacement, Rear Panel: étape 1, image 2 de 2
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
  2. Marshall Stanmore II Rear Panel Replacement: étape 2, image 1 de 2 Marshall Stanmore II Rear Panel Replacement: étape 2, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
  3. Marshall Stanmore II Rear Panel Replacement: étape 3, image 1 de 2 Marshall Stanmore II Rear Panel Replacement: étape 3, image 2 de 2
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
Rebecca Arellano
Membre depuis le 02/05/24
214 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 59
Total : 786
