Aller au contenu principal
Master and Dynamic MW50 Right/Left Speaker Replacement
Ce dont vous avez besoin
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 1 de 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 2 de 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: étape 1, image 3 de 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: étape 2, image 1 de 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: étape 3, image 1 de 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: étape 4, image 1 de 1
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: étape 5, image 1 de 1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Katie Dunnigan
Membre depuis le 01/24/19
85 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G4, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 membres
12 tutoriels rédigés
Un commentaire
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 22
Total : 737
